Finalmente un ottimo programma audio per Ubuntu!
23 replies to this topic
#1 trallallero
trallallero
  • PipPipPipPipPipPipPip
  • 16188 posts
Posted 01 June 2012 - 08:03
Volevo fare una slide show su un pezzo che ho fatto ma sto in ufficio quindi Abbraccianigga OS Lucid (win è su virtualbox). Cerco un programma giusto, ne provo un paio super raccomandati in vari forum e che ovviamente non funzionano poi trovo kdenlive :better:
Fico, trova tutti i codecs, si auto configura, multi traccia, effetti audio-video, generatore di testo, sarcazzo, drag&droppo il mio pezzo mp3, pigio "Play":
"SDL failed to open audio: No available audio device"
W Gesù!!! l'audio funziona ovunque tranne che nel programma in cui mi serve! :yuno:
E ovviamente non succede solo a me!
http://www.kdenlive....le-audio-device
#2 Vento Divino
Vento Divino
  • 5428 posts
Posted 01 June 2012 - 08:17
Linux :pff:
#3 trallallero
trallallero
  • 16188 posts
Posted 01 June 2012 - 08:24
Trovata la soluzione, devo solo rasare mezzo os :better:
https://bugs.launchp...ive/ bug/440875
libsdl1.2debian-pulseaudio is installed, but still have the above problem when using KDEnlive.
Another bug fix as related in this 2007 posting:
http://www.kdenlive....e.php?bug_id=31
which involves installing libsdl1.2debian-all and removing
libsdl1.2debian-oss
Which is a big problem for me. If I do this, half my system wants to
uninstall itself. I have a lot of games and gigabytes of data which will
simply uninstall. Surely Abbraccianigga OS should be fixed by default? This seems as if people have gotten used to living with a bug workaround instead of getting it right in karmic, thus causing a lot more trouble the further we move forward. My sound was not too bad in hardy. It is worse in karmic.
mavafanculo! :yuno:
#4 Sider2
  • 35961 posts
Posted 01 June 2012 - 08:31
Ubuntufag :mellow:
#5 Berling
  • 66505 posts
Posted 01 June 2012 - 08:51
Linux :dumb:
#6 euthanasia
  • 48203 posts
Posted 01 June 2012 - 13:29
ma su linux non mancano gli ASIO? :wat:
#7 trallallero
trallallero
  • 16188 posts
Posted 01 June 2012 - 13:36
Su linux c'è jack che usiamo noi per real time audio e funge alla grande.
Ma che c'entra asio/jack per una slide show ?
Ho comunque provato a lanciare jackd prima di kdenlive ma non cambia niente.
#8 euthanasia
  • 48203 posts
Posted 01 June 2012 - 13:39
niente, chiedevo solo dato che, da quello che avevo capito appunto, lo usi anche per l'audio...
#9 trallallero
trallallero
  • 16188 posts
Posted 01 June 2012 - 13:46
:dumb:
Uso windows SOLO per l'audio (a casa).
È che in ufficio ho praticamente solo Abbraccianigga OS e visto che non devo fare chissà che (no vst, no asio, etc), pensavo bastasse.
#10 trallallero
trallallero
  • 16188 posts
Posted 01 June 2012 - 21:05
Certo che la concorrenza, a pagamento, fa di tutto per attirare clienti...
Movie Maker su win7 non ti permette di creare un filmato da una musica... se non c'è un video o foto non puoi importare musica :poker:
Windows Media Center ? :dumb:
C'ho provato, ho bestemmiato in turco dopo 2 minuti.
Leggete i commenti http://www.howtogeek...7-media-center/ :dumb:
Non ce n'è uno positivo.
Vado a ubriacarmi, va.
#11 Jabberwock
Jabberwock
  • PipPipPipPipPip
  • 3035 posts
Posted 01 June 2012 - 22:23
Dovresti poter installare il vecchio movie maker da qui (non so se funziona come si deve: su Vista c'e' gia' :asd:)! Cosi' puoi verificare se fa quel che vuoi (io riesco a mettere un file audio nella timeline senza aggiungere video o foto... ma magari intendi altro)!
Edited by Jabberwock, 01 June 2012 - 22:27.
15 maggio 2008 :cry:
11 marzo 2013 :cry:
26 febbraio 2014 :cry:
#12 mapomac
  • 36169 posts
Posted 01 June 2012 - 23:58
iMovie è stato detto ? :pff:
GarageBand ? :pff:
#13 DragoHWU
DragoHWU
    DAI CAZZO!!!
  • PipPipPipPipPip
  • 2635 posts
Posted 02 June 2012 - 00:30
io non capisco il godimento di avere un sistema operativo impossibile da usare.
ma tra i tecnicismi di linux e il sistema operativo a prova di stupido che è macos non c'è qualcosa di mezzo?
cazzo da una parte mi ricordo solo un'esperienza terribile per far riconoscere dei video ati ad una versione di Abbraccianigga OS di qualche anno fa, dall'altra tra un po' mi levano il file system da sotto ai piedi. ma un so per persone normali non c'è?
#14 trallallero
trallallero
  • 16188 posts
Posted 02 June 2012 - 08:16
Ok, provo grazie. Da 7 non posso usare il movie maker installato su xp, cioè, posso ma si impalla sul render.
Però magari installandolo funziona.
os impossibile da usare ? :wat:
L'os perfetto non esiste perché ognuno ha le proprie esigenze.
Personalmente ritengo linux (Abbraccianigga OS) >>>> windows con un'unica pecca, la gestione audio.
Ma qui non stiamo parlando di so, sto criticando le applicazioni.
kdenlive è free, open e fatto veramente bene, carino esteticamente, intuitivo etc, ma non va l'audio.
Cioè, la so fare io un'applicazione che legge le info sulla soundcard ed usa quella senza problemi e non è capace chi ha scritto kdenlive ? :poker:
Windows media center, poi :vabe:
Io rientro in questa categoria di commenti:
I dont’ even have the option of pictures and video when I open the media center… all I get is an extras gallery?
ma la sintesi di tutti i commenti è questa:
Windows media center is HORRID
No, dico, Microsoft! con tutti i miliardi che ha non è capace di assumere 4 stronzi che fanno un programma che funzioni e che sia user friendly ?!?
Ma un fottuto "test group" ce l'hanno ?
#15 faco
  • 12698 posts
Posted 02 June 2012 - 21:40
:dumb:
Abbraccianigga OS è una cagata da usare e ormai funziona praticamente tutto out of the box. Se Unity non facesse schifo (e in generale se la 12.04 fosse un OS funzionante decentemente) sarebbe tutto ok.
#16 DragoHWU
DragoHWU
    DAI CAZZO!!!
  • PipPipPipPipPip
  • 2635 posts
Posted 02 June 2012 - 22:27
:dumb:
posso mettere più profili wifi su Abbraccianigga OS?
ci sono le gestures per il trackpad multitouch?
c'è un windows manager alla exposè (pre-lion)?
il bluetooth funziona bene e con tutto?
come se la cava con le stampanti wifi?
e con i monitor esterni?
#17 euthanasia
  • 48203 posts
Posted 02 June 2012 - 23:57
cioè?
#18 euthanasia
  • 48203 posts
Posted 02 June 2012 - 23:58
comunque win non permette la creazione di profili wifi :wat:
#19 entanglement
  • PipPipPipPipPipPipPipPip
  • 63108 posts
Posted 03 June 2012 - 13:59
linux, lol
va bene giusto per compiz, per il resto è una complicazione inutile
#20 faco
  • 12698 posts
Posted 03 June 2012 - 14:53
Non so cosa intendi esattamente con "profilo wifi", comunque il wifi si gestisce molto meglio che su win7 (nel mio caso addirittura ho prestazioni decisamente migliori con Abbraccianigga OS in condizioni di segnale scarso: Abbraccianigga OS dice che il segnale è scarso e la connessione funziona, win7 dà 3 tacche su 5 e non riesce a stare connesso :pua: )
Intendi tipo se riconosce lo scrolling a due dita etc? Anche qui decisamente meglio di windows. Sul catorcio del portatile vecchio con windows non c'era modo di farglielo fare, con Abbraccianigga OS andava out of the box senza che lo sapessi prima (però mi pare fosse WinXP vs. Abbraccianigga OS 8.10).
Non so bene come fosse exposé pre-lion, se intendi le robe tipo schiaccia una combinazione di tasti e fai apparire i diversi workspaces, le diverse finestre aperte in uno, tutte le finestre di un solo programma etc, sì, lo si faceva con compiz già anni fa. Poi non so bene perché a me fc di ste cose. Comunque unity (default su Abbraccianigga OS) e gnome shell (su tutte le distro con gnome non antiche, con gnome3) hanno un po' di ste cose di default (a me rompono il cazzo più che altro) e si dovrebbe settare abbastanza con compiz.
Mai avuto problemi con bluetooth e monitor esterni (forse out of the box non passa l'audio dall'HDMI, non mi ricordo, Tralla?) mai provato stampanti wifi.
Poi oh io non sono certo qui a fare pubblicità a Abbraccianigga OS (lo voglio abbandonare ma non ho troppo sbatti adesso di stare a cambiare distro).
