NEX-5 con 16mm pancake montato
Caratteristiche:
Price • $649.99 / €599.95 / £549.99 (with 16mm F2.8 pancake)
• $699.99 / €649.95 (with 18-55mm zoom lens)
Body material • Magnesium Alloy
Sensor • 23.4 x 15.6 mm Exmor APS HD CMOS Sensor
• 14.2 million effective pixels
Image sizes 3:2
• 14 MP (L)
• 7.4 MP (M)
• 3.5MP (S)
16:9
• 12 MP (L)
• 3.6 MP (M)
• 2.9 MP (S)
File qualities / formats • RAW
• RAW + JPEG Fine
• JPEG Fine
• JPEG Standard
Movie • AVCHD: 1920 x 1080i @ 17Mbps
• MP4: 1440 x 1080i @12Mbps
Dust reduction • Coating on low pass filter
• Sensor-shift
Lenses • Sony E-mount
• Sony Alpha lenses, Minolta and Konica Minolta AF lenses via adaptor
(MF only, exclude power zoom lenses/tele-converters)
Image Stabilization • 'Optical SteadyShot' system on selected lenses
Auto Focus • Contrast AF
• 25 multi-point
• Centre-weighted
• Flexible Spot
Shooting modes • Intelligent Auto
• Program
• Aperture priority
• Shutter priority
• Manual
• Sweep Panorama
• Anti-Motion Blur
• Scene modes (below)
Scene modes • Portrait
• Landscape
• Macro
• Sports Action
• Sunset
• Night view/portrait
• Hand-Held Night Shot
Sensitivity • Auto (Range varies depending on shooting mode)
• ISO 200
• ISO 400
• ISO 800
• ISO 1600
• ISO 3200
• ISO 6400
• ISO 12800
Metering modes • Multi-segment (49 segment Honeycomb pattern)
• Center-weighted
• Spot
Exposure compen. • -2.0 to +2.0 EV
• 0.3 EV steps
Shutter Speed • Electronically controlled, vertical traverse, focal-plane type
• 30 to 1/4000 sec
• Bulb
Aperture values Depends on lens, 0.3 EV steps
White balance • Auto
• Daylight
• Shade
• Cloudy
• Tungsten
• Fluorescent
• Flash
• Color temperature/filter (2500 - 9900 K)
• Manual (Custom)
• Manual (Custom set)
Dynamic range optimizer • Off
• DRAuto
• HDR Auto
Color space • sRGB
• Adobe RGB
Color modes • Standard
• Vivid
• Portrait
• Landscape
• Sunset
• B&W
LCD monitor • 3.0 XtraFine TruBlack LCD
• 920,000 pixels
• Angle adjustable 80 degrees up/45 degrees down
Flash • External flash (supplied), attachable to Smart Accessory Terminal
• GN : 7 meters
• Flash Sync: 1/160sec
Flash modes • Auto
• On
• Off
• Fill-flash
• Slow Sync
• Rear Sync.
• Red-eye reduction on/off selectable for Autoflash and fill-flash mode
Drive modes • Single-frame
• Continuous
• Speed Priority
• 10 sec 3 images
• Bracket Cont 0.3 EV
• Remote CDR
Continuous
shooting • Approx: 2.3 fps
• Speed-priority mode: max 7 fps
• Varies according to shooting conditions and memory card used
Self-timer • 10 sec
• 10 Sec, 3 images
Connectivity • HDMI out (with PhotoTV HD and BRAVIA Sync)
• USB 2.0 Hi-Speed
• Video out (NTSC or PAL)
Storage • Memory Stick Pro Duo
• Pro-HG Duo
• SD/SDHC/SDXC
Power • NP-FW50 Lithium-Ion rechargeable battery
• Battery charger included
• Optional AC adapter
Battery Life (Cipa) 330 shots approx.
Dimensions 111x 59 x 38mm
Weight (body) With battery and memory card: Approx. 287? (10.1 oz)
Supplied accessories Shoulder strap; Battery; Charger; USB cable (miniB); CD?ROM; Flash
Review : http://www.dcresourc...ony/nex5-review
Sony Nex-3
Caratteristiche:
Image Sensor: 14.2 million effective pixels.
Metering: Multi pattern, centre-weighted and spot.
Sensor Size: APS-C-sized CMOS (23.4×15.6mm).
Lens: Sony E Series mount.
Shutter Speed: 30 to 1/4000 second. Flash sync: 1/160 sec.
Continuous Shooting: seven fps.
Memory: Memory Stick PRO Duo, PRO-HG Duo, SD, SDHC, SDXC cards.
Image Sizes (pixels): 4592×3056, 4592×2576, 3344×2224, 3344×1872, 2288×1520, 2288×1280.
Movies: 1280×720, 848×480, 640×480 at 30 fps.
Colour Space: sRGB, Adobe RGB.
LCD Screen: 7.5cm LCD (921,600 pixels).
File Formats: JPEG, RAW, JPEG+RAW, MPEG4.
ISO Sensitivity: Auto, 200 to 12,800.
Interface: USB 2.0, HDMNI, AV.
Power: Rechargeable lithium ion battery, DC input.
Dimensions: 117.2×62.6×33.4mm WHDmm.
Weight: 297 g (inc battery and card).
Price: Around AUD1000 for body and kit lens.
Sito Ufficiale : http://www.sony.it/h...eflex/nex5-nex3
Lenti native per E-mount disponibili al momento:
Sony E 16mm f2,8
Sony E 18-55mm f3,5/5,6
Sony E 18-200mm f3,5/6,3
Accessori: http://www.sony.it/h...eflex/obiettivi Spulciate i menù in fondo alla pagina per trovare altra roba..
Compatibili tramite adattatore Tutte le lenti con Baionetta Alpha e Minolta - Le lenti con motore incorporato verranno pienamente supportate dopo un aggiornamento software che sony ha promesso a breve - Le lenti non motorizzate saranno utilizzabili in manual focus mantenendo però gli automatismi.
